V6.21 update ???
seaveekarma
I am using an external DFF3.
Is it necessary to reset the internal sounder and MFG if I don't use and wont ever use the internal sounder? (Part 3 & 4 of update.)
Assuming the reset of the MFG and sounder are not necessary for my application, do I still need to download my settings and points to a USB prior to the update?
Assuming that Part 3 & 4 must be done, can I backup my settings and points on the same USB that Part 2 of the update is stored on or does it need to be a separate USB?
Thanks in advance.
Can I backup my settings and points on the same USB that Part 2 of the update is stored on or does it need to be a separate USB?
Yes you could use the same USB. You don't want to have the USB plugged in until the unit is already up and running; then you can back up your data.
I cannot get my unit to run the second part of the update, from usb drive. When I format and load the part 2 data, all looks good. I insert into drive, turn on machine and it boots up and runs but does not “beep” and read drive, so charts and photos are not updating.
Then when I shut it down, take out the usb and view it’s content on my laptop, there is a “lost dir “ file.
I wouldn't recommend reformatting a USB that was just working well. Normally just delete the files and put on the new stuff. I can only guess it doesn't like the format. Also note that part two of 6.21 is to update the internal sounder, internal users guide, and a few other things. It will not change your maps. Your primary navigational maps are held on a chart card that you will re-insert after the update process. If you continue to have problem getting Part2 to work, I recommend contacting technical support while you are at the unit. They might be able to talk you through any problem. Alternately, update kits (pre-setup media) are available for purchase from your dealer.
When I did my update, the second part would not load. I talked to technical support and they suggested a different USB stick. I bought a cheap SanDisk Cruzer, loaded update, re ran the update program and it downloaded and went right through.
