Anyone experience booting issues after updating to software version 25 that was just released?
I had to do the update with a USB and it went thru fine. When I turn the unit on, the white bar begins to load until it reaches the end and it starts again, this continues and the display never actually loads or turns on, it did this for 30 minutes without powering on. Reinstalled the software and still did it. I held the power button for 5 seconds, released 5 seconds and repeated unit the reset menu came up. Reset all the settings and it powered on correctly. Turned the display off and tried to power it on and the same failing to boot issue is happening. Now the reset menu won't come up holding and releasing the power button.
Hoping someone has a resolution for this.
