Quitsa
I am in process of building a new boat and am having a lot of trouble getting information on interfacing the Cummins/Smartcraft Vessel View v2.5 engine monitoring system for my Diesels to the TZTouch system I expect to fit (though you may lose the sale if I don't see a path to a CHIRP sounder black box soon!).
The VesselView is basically a J1939 CAN bus system that should be compatible with your proprietary/NMEA 2000 networks. But I only see a NMEA 0183 adapter for the Vessel View which I guess gets it GPS SOG data primarily so it can display fuel economy and range.
Can you tell me how to interface the VesselView 2.5 to a TZTouch system?
On my old boat it was pretty easy. I had Volvo engines and the Volvo EVC system has a NMEA 2000 adapter that connects to the harness and allows connecting as a drop on the NMEA2000 backbone. I used that with a NavNet 3D system quite successfully and got all the engine data on the MFDs.
