Fletch10au
Hi all, just chasing some recommendations. I have a fiberglass trailer boat, 21.5 foot (6.4m) long and have a TZTL12F (TZT2) installed in the dash. At the moment it is only running a 525T-PWD transducer, which generally works fine in 2D and for bottom discrimination etc.
I've established (please correct me if I'm wrong) that if I want to add side-scan, my only real option is via adding a DFF-3D, and am prepared to do so. I generally fish 15m (50ft) through to 100m (330ft) and want the side scan feature of the DFF-3D for identifying targets and then the existing 2D and bottom discrimination for more detailed scans.
My questions are:
1) Can I run my existing 525T-PWD transom mount transducer and a sidescan transducer on the DFF-3D and display both on TZTL12F at same time?
2) Would I be better off replacing my transom mount transducer with a combo (ie 165T-50/200-TM260)?
3) If I can run my two transducers on the DFF-3D, assuming I keep the 525T-PWD, what other transducer would you recommend?
Apologies, there is a bit to ponder there, but figured someone else may have been through this process.
My questions are:
