Hello,
I would like to upgrade a my transducer setup. I would like to know if it is possible to run this setup.
My current setup is TZT3 9" and 12" MFDs, Dff3D with 165T-TM54, and V60 thru Hill.
I would like to swap out the 165T-TM54 for a 165T-B54 in a fairing block trimmed to fit a 20 degree dead rise. Add a b175m thru hull and keep the B60. Then add a Furuno transom mounted side scan transducer.
I would like to connect the B60 to the 9" MFD. Then connect the B175M to the 12" MFD. The Dff3d connects via the hub. How can I connect the side scan transducer?
