tzt3 b265lh help
You mean bottom discrimination? No, at this time only select CW transducers offer that feature with the TZT3. The TZT3 hasn't been out long and I am sure that advancements with the software will happen just as it has with the prior systems.
Can I tag to this chat and validate if Airmar M265C-LH Broadband CHIRP can be detected by a TZT3 12F/16 without a DDF1 module?
Thinking of getting another set of TZT3 + Airmar M265C-LH BARE WIRED, CONNECT TO FURUNO 12PIN BARE WIRED. Wonder the TZT3 can pick up and identify the transducer as it is not listed per FURUNO website.
Anyone with experience appreciated.
It isn't currently listed in the software, but it has the same transducer elements as the B265LH, so it could be wired up and the B265LH selected instead. You could use it direct with the TZT3 internal sounder.
My TZT3 12” is only Using / When using the manual ducer setup option it’s recognizing 50/200 and I can’t seem to figure out how to get it to chirp - I try to change the frequency in the settings and it goes back to 50/200 - I am using the b265LH ducer. Also when at the marina the LOw 50kh doesn’t want to stay locked in . Help
And in Then when I use the model setup it uses 170 for high and 53 for low- Still not saying or giving a chirp option. -
Troutderby I suggest you start a new post with the details of what transducer, what pin count on the transducer, and what software on the tzt3.
