TZT2 Transducer Question
haneyrm
I need a new transducer to replace my current B117. The Furuno 520-BLD looks like the correct replacement but I do not see where it says it includes temperature.
Can anybody confirm that the current version of this transducer includes temperature?
Thanks.
It does not contain temperature.
The 520T-BLD does.
If you want to take advantage of RezBoost or bottom discrimination you might look into the 525T-BSD or any other transducers listed for these functions.
Does Furuno offer a B117 direct replacement that allows for the use of Rezboost? Seems like it shouldn't be a problem since the B60 (525T-LTD/12) is supported and I believe the B60 and B117 have the same internals other than tilted element. Is this not correct? I don't really need bottom discrimination but would like to use Rezboost if possible.
Thanks.
You are correct that the B60 and B117 have the same elements. Our 525T-LTD/12 will enable Rezboost.
