I updated my chart files and now it does not appear that the unit is reading the charts. My SD card has a 2 directories on it. One is called NOAA USA and the other is called Std Res SAT Photos. There is also a file in the root directory called catalogue.zic. Under the NOAA USA directory there are 4 sub-directories. They are labeled 3D, Fishing_Charts, Raster and Vector.
When the SD card is in the machine, it will only show a single raster chart and the satellite images. I want to use the electronic vector chart that shows channel markers and nav aids. i like being to click on a marker and get info. None of the other charts on the card will display. On the plotter screen, I only have option of Auto or Raster. No options for Vector, Fishing, etc.
I'm not certain I have the correct directory structure on this card or have the files stored in the correct locations.
Can somebody help point me in the right direction? If you need to know what files I have under each directory, just let me know and I'll post everything.
Thanks.
Thanks.
