Having finally got my TZT2 back from the dealer (to get the missing eGuide installed) I realised that the heading data I was seeing was way off. I instantly knew the reason for this, I have a few heading sensors available, one of them is right next to a steel pontoon - I don't use it as I have a mega accurate Airmar H2183 sensor. When I dived into the data source screen though hardly anything is there! All my devices show in the sensors screen, but only a couple show in the devices screen, and when the little arrow shows to choose then there is only one entry (the one that is already there! - usually the TZT2) note the ZG100 is seen as an attitude/pitch roll device - even though it's not great for that (but I get no choice) but it isn't seen for position - which it is good for!
I use these sensors all over the place - TZ Navigator, Open CPN, Furuno FI-70 I know they are working!
In the list you will see an NMEA bridge, this has everything from the NMEA 0183, including old heading sensors (which is how I spotted the issue) but for instance the position is being taken by the internal TZT sensor, there are 3 other GPS on the bus, one through the NMEA bridge + a 10hz B&G ZG100 and a 10hz XB8000, none of which are selectable, I used to be able to choose (and had chosen the NMEA bridge as tat made the Doppler work on the radar)
Am I doing something wrong (again!?!?) any ideas how I can get the system to let me choose the sensors to use?
Any help much appreciated...
...(c)
Sensors List
Device List
Using same sensors in FI-70, plugged in right next to the TZT2
...(c)
Sensors List
Device List
