Only if the same exact location. If the same location color etc; then it is a duplicate.
Johnny Electron":1gnoqeyd said:The log file will normally go back to the last factory reset/clear. Anyone that has a continuing problem should open an official support case with tech support and providing the log file is a good start to see what might causing an issue. Duplicate waypoints can cause rebooting as can any bad user data like corrupt tracks.
CBBeaty":2ov689vo said:Update
!0 hours offshore today and no reboot or shut down after spending 4 hours going thru waypoints and eliminating duplicates> Very happy!
Johnny Electron":8yg6y8kb said:It sounds like either the proper chart master setting has been turned off or got cleared during a factory reset, or the unit has unlock codes for charts that don't match the chart master currently being used. This can happen if someone turned the setting on for the wrong unit which wasn't the master prior.
Johnny Electron":20a0v883 said:Then the notice you had about the charts was most likely stating that the chart master was turned off and that your charts would be limited to XX power cycles until it sees the master. This happens if the chart master is turned off for several power cycles and the slave doesn't see legal licence to the charts it currently has unlocked. That isn't an error but a notice.
