TZT16F Use as Touch Display?
arashi01
Hi,
Looking for 2 x 15.6" Full HD touch displays to use in an installation with a PC running TimeZero Professional.
I notice that the TZT16F datasheet lists an HDMI input under Video I/O and, also lists "1 Port (USB2.0) for touch monitor and control unit: 1 Port USB output" under USB.
This isn't clear to me whether the USB output port listed is for touch output if using the HDMI input, or for some other purpose. Can anyone confirm?
As long as the PC accepts standard touch control via USB, it is common to be able to Bring in PC video via HDMI and allow the touch control to control the PC. We do this a lot at boat shows for Nobeltec software or WASSP. The touch control out requires the use of USB2 and the software setting be setup to send the touch control out. This works like having one touch screen monitor for the PC. The complex point is you are talking running two screens and not sure how that would work.
