Good morning Intrepid26,
Thank you for your feedback. Just to confirm, once you manually entered the frequency specifications in the menu, you powered the DFF3 off, then back on again? The power needs to be cycled on the DFF3 in order to lock in the transducer specifications that you input on the TZT unit.
Looking at the software for the DFF3, version 1.05 is the latest revision available here in the states. So according to those numbers the DFF3 is at the latest version. You also indicated that the TZT14 is runing version 4.21, that is not the latest version of software available, it is one revision behind. With all that being said, I do not believe it is an issue with the software version that the units are running. There could be an incomplete software load causing the fault but I believe the version of software on both units is capable of running the two units together. Hope that makes sense.
Please try to confirm that power was cycled on the the DFF3 before trying to use it after the transducer selection has been made in the menu. Powering down the TZT 14 will not achieve this result. The DFF3 must be powered off at the breaker, or source.
Kind Regards,
C-Bass
