Mounting can cause things to resonate so sounds can vary from install to install. There is an internal fan and it is normal to hear it to some degree. If the fan has a problem with its speed or stops turning the display will throw a "Fan Speed" alarm that you can't miss. I would review the mounting and ensure nothing is binding into the case and if resonating, you might need to add some cushion foam to quiet the console. If you have a very noisy fan that works but really abnormal it could always been sent in for repair evaluation and a new fan installed. Because the units have two year of warranty (three years if purchased from FUSA from May 2020 to Dec 2020 and registered within 90 days), you might wait until a convenient time to send it in. The fan shouldn't keep you from fishing unless you start seeing some alarms.
