Quitsa
One thing that is still very unclear from the manual and other literature is whether it is possible to run the internal TZT 3 sounder in conventional 200/50 Hz mode if you have a CHIRP capable transducer. It seems to select the transmission mode based on the transducer iD so if you have a CHIRP transducer, it automatically transmits spread spectrum CHIRP. The only choice is LF or HF.
The "brand G" sounder frequency menu allows the user to select (using HF as an example) 200Hz, a custom fixed frequency anywhere in the range (160-250Hz), or high frequency CHIRP if it detects a CHIRP transducer. This is a nice feature and it would be a shame if G actually had something better than Furuno! It looks as though if you add the external DI-FFAMP, it is possible to use custom fixed frequencies but only if you have that hardware on the system. Is that right?
I don't know if this is a hardware or software issue. If it is software, maybe the guys in Japan could add frequency selection to their list of future improvements.
