I have an FI-501 wind instrument, using an FI-5001 wind transducer. The FI-501 indicates Apparent and True wind correctly. So far, so good.
The FI-501 is connected by drop to an FI-5002 NMEA 2000 Junction Box. Speed and COG info come from an SC-30 sat compass into the J-box by backbone (with a GP-330 as a backup). Also networked to the J-box are two TZT-14 MFDs. (Additionally the two MFDs are connected to an Ethernet Hub 101, which connects to FA-50 AIS and DFF1, but I don't believe this is relevant to my question).
So the problem is that while the FI-501 displays true and apparent wind OK, the TZTs only display apparent. The blue direction arrow (true) hides behind the red arrow (apparent), and both true and apparent display only the apparent wind speed. The input for apparent on the TZTs is set for the FI-501. The input for true is set to NMEA2000 (no other option).
Question is, where is the true wind calculation taking place? I'm presuming it's in the FI-501, which then puts that info onto the NMEA 2000 bus.
Now before any conclusions are drawn, I have to add that WITHOUT ANY CHANGES TO SETTINGS IN THE FI-501 OR TZTs, this setup did work properly for about a month. Then quit again. So I do not believe this is a setup issue.
Any help much appreciated!
