R
Richardt01
I just had all my Furuno electronics updated on my 2006 Southport center console. I went from a Vx2 to the new TZT2 and from a 600 wt transom transducer to a Airmar B260 thru hull. My old system worked great but I want to deep drop and it was marginal out past 250'.
My sounder will now only read in very shallow water at very low speeds. I have checked all the settings. Its set for manual 1kw 50/200hz , auto range off, gain 50-60 picture advance 1:1
transmission power 10, bottom level high between -25 and -35 bottom level low between -25 to -35 and still wont read in anything over 10 feet and nothing at any kind of speed in any depth. Even did a hard reset on the unit with no change. Anything else to try? I updated this unit so I could deep drop with it and now I'm dead in the water.
Thank you,
Richard
Thank you,
Richard
