Aloha All,
I'm in the process of outfitting my new boat with a new transducer/ sonar. Appreciate your advice in advance.
Parameters
-Trailered 24ft planing hull with volvo diesel duo prop sterndrive
-Previous owner had a pole mount transducer, could drop it about 2ft below ocean surface.
-Locate deep drop structure while trolling at 5-12knots
-Deep drop/ bottom fish 600-1500ft
-Mainly focused on 1kW transducers for budget reasons
Question
Of the several transducer mounting options which type gives optimal performance?
Discussion
-Of all the reading I have done wet face gives an advantage over shoot-thru for the typical install.
-On small boats like mine the hull turbulent layer is thin so flush thru-hulls (ie SS264, B175 style) work well.
-Transom mount (ie TM265/260/270) are easy to install, but can be finicky with the turbulence coming off the hull.
-Thru-hull w/ fairing not appropriate for small trailered boats...but what about on a pole mount off the swim step? Are the B260 type Tx even waterproof at the wire connection?
Mahalo,
Sean
Parameters
Question
Discussion
Mahalo,
Sean
