My current boat came with a vx2 plotter and a dff1 sounder. It has two transducers. One was networked directly to the dff1 and the other was connected directly to the vx2. The transducer into the dff1 connects via the 10 pin and works with the upgraded tzt2 that I upgraded to just fine. The transducer that connected directly to the vx2 can no longer connect to my system. The issue that this has created is that I am no longer able to see SST as the transducer with the vx2 compatible connection had SST and the one with the 10 pin connection does not.
I purchased one connection cable to convert the SST transducer from the vx2 connection to 10 pin and it was the incorrect one. Can anyone tell me the airmar/furuno cable that will allow me to connect the vx2 compatible transducer cable to the 10 pin that will plug into the tzt2 so that I can get SST to my plotter?
JP
JP
