Lost my transom mounted transducer when mount snapped and the prop cut it off.
My question is I have plenty of cable left and want to install a thru hull transducer and rather than running a new cable to the center console ( tight squeeze ) can I wire it directly to the new transducer?
I could also add a connector to the cut end if I could get the pin out. Any advice on how I can connect a new thru hull transducer to the 6 wire cable that use to be connected to the P66 transducer.
