Hello,
I bought my Scout 262 in 2007/2008 and had a full Navnet VX2 system in stalled and set up including Charts, Sounder, Radar and Symrad Autopilot. From my warranty registration email this is my serial number BBWGPS SN# 4411-5765
It's the GD-1920C with Radar.
I updated the software and maps in 2012ish to C-Maps and used it perfectly for a year or so. Then life happened and the boat sat on the trailer for the next 10 years.
This year I got the boat back in the water and everything is working well apart from the Sounder. I did just update the C-Maps to the latest version last week.
Now it's been a while but I remember my dealer telling me an important start up sequence. I can't remember what it was though.. it involved the order of the Master Electronics switch, maybe the accessory electronics switch and the main Furuno head unit power on.
Now when I first got the boat in the water again everything worked apart from the sounder. I thought something may be bad but nothing was obviously wrong. Next day everything worked including the sounder! I think I may have turned everything on with a different sequence but I am not certain.
Today the sounder wasn't working again. I tried every sequence possible and no luck. Could I have messed something up doing the wrong sequence? Anyone know if the main accessory should be on first or after the head unit? Anything I should go through and check? Nothing looks loose on the back of the head unit.
I have tried to read up here as there is so much good information, but I am not sure what is relevant to my unit or not. Do I have an internal battery that needs replacing? Can I do that myself? I am trying to get as much information as possible as the boat is an hour and a half away and I want to be as prepared as possible for the next time I go down to it, so I can work out a solution
I will attach some photo's to see if they help.
Thank you
Thank you
