I have a short keel and I think I have 2 viable options to mount the 225T-SS904. One is directly on the keel. I am not sure about the hull thickness there so it may not work. If that idea does not work I have an area behind the keel that is between the shaft exits. I have good access to that area inside the engine room. The pic shows the basic area for each location. I will only be using side scan while trolling "avg 6-7 knots" so I do not think there will be a problem with turbulence from the rear of the keel.
I really like the idea of the area between the shaft exits. The transducer would be well protected and access inside is great. I am concerned about the interference from the shafts but they should be above the beam of the transducer.
I already have the single 225T-SS904 and I am hoping one of these locations will work.
