Is it possible to share transducers on a GP1971F, using some type of "A/B" switch? Suppose I have a 600W P66 and I also wish to add a 600W CHIRP transducer to use in deeper water? Could I simply install a "switch" (If one even exists with the right interface) , allowing me to select between my CHIRP and non-CHIRP transducers? If so, it would seem I would have to change the transducer settting in the GP1971F each time to select the transducer in use. Or, is this idea merely a pipe dream?
Thank You.
Thank You.
