Two TZT3 units in a network. Each TZT3 has a transducer connected to it. We will call them TZT3 Port & TZT3 Starboard. I want to use the transducer connected to the TZT3 Port device as the source for SST data. Therefore, I select TZT3 Port as the source for SST data for both units. Generally speaking, this works, and both units will show SST as measured by the transducer plugged into the TZT3 Port unit.
However, when viewing the sonar screen on the port unit, if I change the transducer I'm viewing on this screen (not changing anything physical, just selecting the Starboard unit as the sonar source to be displayed on the Port screen), the SST data changes on both screens and now is from the transducer plugged into the Starboard unit, even though the source is set to Port. Is there a way to stop this behavior or is it just a bug? What if I disconnect the temperature wires going to the Starboard unit as a workaround?
