SCX20 setup menu
threadfin
I've just installed an SCX20 on my NMEA 2000 backbone. My TZT3 16 and Navpilot are also connected. Could someone walk me through, how I access the set up menu on the TZT, to set up the unit, please?
I note that these instructions state that the installation location values are to improve accuracy of the 3 axis speed calculations. For some reason, I thought these parameters were primarily for the heaving correction calculations. Is that not the case?
The 3 axis speed is lateral speed at the 3 points you pick...i.e. Bow, Stern, and usually the center of gravity (usually where your standing conning position).
Heaving is setup in the fishfinder menu and you enter the installation position of the SCX relative to the transducer position.
