Is it plausible that a CSH-8L transceiver could damage the transducers of nearby 1kw (or 2kw) bottom machines? Especially if the tilt is left horizontal/in plane of the victim transducer for an extended period. (Pick any retail airmar fishfinder type transducer as the victim)
If so, what is the minimum safe range between the sonar transceiver and the bottom machine transducers? I believe the KP transmit trigger may be intended to protect the units, but this is just a WAG.
Thanks for any advice you might have!
