Scanner to monitor cable?
Hi guys and welcome from the uk. I'm after some info and help on my 1942 radar it has a open scanner and the model is a rsb-0062 . I'm lookin for a new cable to connect them back together as old one is damaged,ideally lookin for some part numbers to try and source one ASAP. many thanks steve ;)
M
Melville
000-138-970 15 Meter Signal Cable Assembly
000-138-972 10 Meter Signal Cable Assembly
000-138-973 30 Meter Signal Cable Assembly
000-138-974 20 Meter Signal Cable Assembly
These are the part number we use here in the USA. They may be different in other areas.
I suggest you check with Furuno UK.
Havant: West Building, Penner Road, Havant, Hampshire, PO9 1QY Phone: 02392 441000Fax: 02392 484316
Aberdeen: South Breakwater, Fraserburgh, Aberdeenshire, AB43 9TD Phone: 01346 518300Fax: 01346 512545
