SC33 with IF-NMEASC and SC33 software
GWB
When connecting to the IF-NMEASC with the USB port on the IF-NMEASC, how do I access the SC33 to make setting changes? I do not have a full NMEA200 network on this boat, only the SC33 connected to the IF-NMEASC with appropriate cable. To be clear, everything is working, we just need a way to monitor and change the SC33 settings
For the SC30 The USB port is dealer/installer to connect a PC to configure the unit with the SC30 SCtool software. It can also be used for some limited troubleshooting. The SC30 software and instructions was on our website under the product but appears to have dropped off. I will have them update it. The software will show up within the next 24 hours.
For the SC33 it is different. When using the IF-NMEASC with it, you configure the 0183 ports with the buttons inside the If-NMEASC box. The SC33 is not the same as the SC30. It has different SC Tool software and communicates diffrently. You can not use the USB port inside the IF-NMEASC. That only works for the SC30 and it's software. To configure the SC33, you would use the SC33 tool software and instructions. Here is a direct link to the SC33 tool manual.
https://www.furunousa.com/-/media/sites ... manual.pdf
I notice the SC33 tool software is missing on our website. Our IT guys are looking into that now. It should be be restored shortly. If you need the software urgently you can contact tech support and they can get you a copy.
