M Meanwhile Member May 16, 2022 #1 Can you advise if a GP320B, serial number 4448-9827 is affected by a roll over issue? Will it still provide an accurate location to my System? Will the DCS on my radio that is taking the position from my system still work? Randy Kane Warren, OR
Johnny Electron Administrator Staff member May 16, 2022 #2 At this stage all GP320B units have rolled over regardless of serial number. Position is normally not affected, only the Time/Date. Depending on the plotter used, most use the GP330B/0183 as the plug and play replacement to the older GP320B.
M Meanwhile Member May 26, 2022 #4 When I replace the GPS antenna, can one antenna be shared with two displays? I ask as I now have two antenna. 10" and 7" VX2 displays.
M Magnetron Guest May 26, 2022 #5 Meanwhile":3vcrm48b said: When I replace the GPS antenna, can one antenna be shared with two displays? I ask as I now have two antenna. 10" and 7" VX2 displays. Click to expand... If they're networked together, yes the new GPS antenna will port GPS over to the other plotter. No need to run two antennas, one is sufficient. Hope this helps, :sail - Maggy
