Restore from cloud onto new machine
Don Sol
Ive just received a new XL13 on warranty. Ive done the restore of all my settings, waypoints and photos (ie screenshots) from the cloud, which is just an epic service. However it seems the screen shots do not want to display. So they icons are displayed on the plotter, the pics are listed in the "list" file but when i want to open or display the photo it comes up as a white dot. See the pics below.
am i missing a setting, any tips or tricks to have these pics displayed?
thanks
Updates to this issue..... 1stly along with this issue above ive had zero LOW FREQ display on dual freq, i run a 600w P66 transducer, the depth reference numbers on the side of the RHS of the screen does not come up, its absolutely blank. when i run single freq. on LF, I get a sea bed display however it will always auto range and jumps to 80m, even when auto range is off. These faults also happen when im on DEMO mode, it runs exactly the same as at sea. I also get an unknown alarm as start up SID .... see pics attached. I then did a HARD factory reset on the serviceman page and initially did NOT connect back to TZ cloud account. Set up the machine as i would and perfect LF and HF freq use, displayed properly etc both live and DEMO. I installed my TZ cloud data, FYI the screen shot displayed perfectly, so the fault described above is no longer an issue and still the LF and HF displayed perfect. I then took the boat to sea and bingo the LF fault is back, with the same fault. The screen shot images work fine, that is great.
Whenever a screen capture is done it will save a copy to the machine and to the USB stick (if one is inserted). I almost sounds like you have some bad user data that is being restored from the cloud backup. I also note that it looks like after clearing the unit the chart master setting was not turned ON for the master unit. The P66 has a 10 pin connection that goes to the Furuno 10 pin to 12 pin Furuno adaptor with the blue plastic?
Hi Johnny, yes ive connected the P66 via the 10 to 12 adapter cable. Into the machine. The HF seems to work fine.
That SID error pic attached above is not my machines system ID number. This is a brand new machine out the box and that error message came up with what may be a different machines SID. Not sure where that comes from.
I will run another full factory reset and then without signing in my TZ CLOUD and or restoring from the cloud ill see if there is any failure in the LF .
OK i have an update:
Did a factory reset and a clear Cache and without downloading or importing my time zero data the LF worked 100%. I restarted a few times and ya it all worked 100%, I then did a restore from the cloud, did a restart and the LF failed again as described above.
1. Is the data on the cloud compatible with a new machine and new system ID?
2. How do i clear the old file? and to what extent do i loose data? so the screen shots and waypoints ?
Its easy to set up the machine again, but how do i keep the waypoints and screen shots
Sounds like we are getting someplace. There is something in that data that the unit doesn't like and it slowing down processing to the point of causing the sounder performance issues. I would recommend sending a copy of the routes and points to tech support so they can run it through TimeZero software and clean up the data and look for any issues. Once they send you corrected copy, factory clear the machine and import the data. Do not use the cloud. Do not restore any backup SETTINGS. Set the unit up by hand. Verify that everything is good, then connect to the clould and backup everything (overwriting the old stuff).
UPDATE:
So started from scratch, set the machine up from scratch. Everything working perfect!
I then linked up to the internet and signed into TZ cloud, noticed straight away that the unit was syncing. It loaded my waypoints and screen shots, nothing else. I did not restore the unit from the cloud. ANyway all my waypoints came down as well as screen shots everything worked 100%.. did a few restarts and ya everything worked perfect. SO i think the corrupted file is the unit setup that was backed up on the cloud. SO ive backed up the current set up to the cloud. everything is still working fine. had an epic day at sea today! thanks a million.
Some additional info, I had a flash drive in the unit to collect screen shots and before i did the 1st Hard reset i backed up everything to the flash drive, including the units set up specs. When i placed the USB into my PC it was totally corrupted, it would not stay open and auto ejected within a few seconds. I did manage to see that it had stopped collecting screen shots at the same time that i backed up all the data to it. SO yes there was something very seriously wrong with the data package before. i have discarded the flash drive.
