On my boat, the "%Full" display of fuel level shown by the TZT14s is correct but "Fuel Remaining" is always zero. An actual zero is displayed, not a dash, so the TZT14 thinks it is getting data. The Cummins/Mercury Vesselview display of %Full and Fuel Remaining is correct. My understanding of the setup is that the VesselView receives fuel level from the tanks sensors and forwards it to the TZT14's via a Cummins/Mercury "NMEA2000 Gateway". The fact that powering off the Vesselview causes the zero on the TZT14s to change to a dash seems to confirm that.
There is no way I could find to specify fuel tank size in the TZT14 setup, so the only way I can think of for %Full to be correct and for "Fuel Remaining" to be zero is for there to be separate NMEA sentences for each of those items (or perhaps just for tank size). It seems strange that one should pass through the interface correctly and the other not when they are really different display formats for the same underlying information. RPM, fuel flow and rudder angle are displayed correctly by the TZT14's, so quite a bit of data is getting through correctly.
A problem that may be related to the TZT14's thinking that Fuel Remaining is zero is that I get a "Fuel Capacity Alarm For Active Route" warning popup whenever I navigate to a point. I can't find that alarm in the list of alarms. I would like to disable it at least until the Fuel Remaining data gets across the interface correctly.
I realize that the Cummins/Mercury NMEA2000 Gateway is a likely suspect, and will ask them the same questions, but hopefully someone here has already solved the problem.
---rick
---rick
