Raymarine b265lm to TZT3
No Plan
Hey Guys,
I would like to covert my boat from Raymarine to TZT3s. I have a Raymarine b265lm transducer (a80011) hooked up to a Raymarine cp450 sounder. Is there any way to cut the plug and wire on a Furuno pigtail and still get both frequencies plus temp?
Thanks!
No problem whatsoever. You would cut off the connector and wire on the Furuno 12 pin connection using a 12 pin pigtail cable (p/n TZ3-12P-PGT). It isn't possible to use the 12 to 10 pin adapter cable that comes with the unit because there are not enough wires in it to wire both frequencies.
