Radar FAR-2827 FAILURE
X-BAND RADAR FAILURE.
The picture on the radar screen froze. Turned the power Off.
After “POWER” BUTTON is pushed, the coolers in processor unit
start rotating,processor unit trying to start.
After 2sec coolers stopped and system shut down.
When pushed Power button system shutdown again.
So,the radar system even do not start.
Blown fuse F1 on processor unit checked and found OK.
Main voltage/polarity checked – OK.
In my opinion it is problem with power supply unit.
Need advice.
Alex Dubrovsky-
This forum is not the correct place to resolve your issue. Please send an email to our Deep Sea department who will be better able to address your problem or direct you to the nearest service agent.
fusa.deepsea@furuno.com
Most likely the HV power supply board, causing the power supply to shut down. Disconnect the HV power supply input from main PS board, see if it still shuts down.
Becotm-
Thank you for joining the forum. You do realize that this topic is almost 3 years old and most likely has been resolved.
