I installed a 1623 radar installed on my small trawler about three years ago.  I have used it only a limited amount until the last month when I used it almost continuously for several days operating in the fog.  Unfortunately, the radar now stops working after about five minutes of active transmission, it then works intermittently, 30 seconds on, two to three minutes off.  There is only 11 hours on the unit  in the transmission mode, and 12 hours in the standby mode.  I am located on the Virginia portion of the eastern shore of Virginia,  and there are no Furuno dealers here.  My first thought was that the magnetron failed, and I could order a replacement and install it, but I have read in previous posts that the average life of a magnetron is 3000 hours, so this may not be the issue.  Can you recommend a path of action to fix the scanner.  Thank-you.  Joe
