Prevent fish finder change transducer setting
frankiepr
I have a tzt3 and tzt2 and each of the MFD has its own transducer. Tzt3 has a transducer 526TID-LTD and the Tzt has a P66 transducer. I have noticed that when the transducer set up is done in one of the MFD, the other changes its setting. In the sensor list I setup stb and port preferences of each MFD. How do I prevent this set up change it?
Ensure that you have changed the sounder source before doing the transducer setup. When running two internal sounders, it is important to nickname each MFD in the sensor list so you know which you are selecting and talking with. Name one Starboard MFD and the other Port MFD, then when you select the fish finder under the fish finder menu, you can ensure you know which you are talking with. Currently you are talking to the same sounder from both units.
