bporter51317
I've recently been forced to upgrade from my 511 to a 711C due to additional FAP6011 control heads no longer being available to replace my second station.
I am attempting to re-use the old PG-500 with the FAP-7002.
With the FAP-5002 the PG-500 was required to be powered from the main autopilot unit to work correctly, and there were pins on the HDG/TB8 block to provide the power to the compass.
With the 7002, I see the NMEA 0183 blocks but they have no power like the old TB8 did since the new PG-700 presumably has it's own power source (on N2K maybe).
I don't have a ready source of power available near the compass except the autopilot, as that's how it had to be installed with the 5002. I want the PG-500 to be on when the autopilot is on, and off when the autopilot is off, just like it was with the 5002.
So I'm not sure where to power the PG-500 from in the new installation. I see several things that look like they could work from the 7002.
The rest of my boat is N2K, and I plan to connect it to the AP at the CANbus connection, it's just another drop in the network and does not need to provide power to the bus. So TB12 is unused.
So I'm thinking I could just send the power and ground cables from the PB-500 bundle to the TB12 net power block.
Would that work?
There also look to be a couple of 12V+ / GND connections on TB5. Could any of those work instead? It's not clear if those are always on with the autopilot or are intermittent.
Would that work?
