I have been running the NN3D for the last couple of years with a MFD12 and 8 Ver2.11 displays without any major issues. I recently purchased an FCV1150 and have connected through a Furuno hub. The problem I am having is the FCV1150 (it is in NavNet mode) will not display any depth. The MFD12 sees the FCV1150 and can control the functions but will not fire the transducer. If I set the sounder to the DFF1 everything works as it has been. I have reset the LF tap to A and the HF to A according to the May 16 release, screen rate is 1/1, TX rate @20, TX power @10, LF set manual @ 42Khz, HF @200Khz. What am I missing? Thank you
