NMEA outputs and problems
buckshot
I realized that I had multiple data sources in my NMEA 2000 network so I turned off most of the pgn outputs on both TZT16's.
I have 2 TZT3 16's, SCX20, 711C -fap 7002, fusion bb100, and a Yacht Devices YDNB-07 . The YDNB-07 is to isolate my engine network.
I only have these on
CTE 129283
Nav 129284
nav 129285
Temp 130312
temp 130316
I am now having fusion BB100 difficulties , it shows in the sensors list but is not available to control on the MFD. The Fusion NMEA remote shows "waiting for stereo" It will play music for a minute or so then turn off.
I also tried to go to my scx-20 setup screen and when it booted I only had a blank white screen, I tried it couple of times and restarted the MFD's.
Are there any PGN's that I have shut off that could cause problems like this? I did not think so but figured I would ask before I go troubleshoot.
If you want to pass water temp; the PGN that should be ON is the Environmental parameters and then turn the other two temps off. These are not your problem. It looks like you have a problem with the 2000 bus maybe related to the fusion based on our other thread. https://furunousaforum.com/threads/fusion-bb100-not-showing.19728/#post-49100
I would recommend removing the Fusion from the bus and see if you can get everything else working fine, then work on why the Fusion is a problem.
unplugged every NMEA connection and went through them one at a time. Now everything works fine with no idea what was the culprit to my problems. 🤬🤬 Well at least it is working, for now anyway:unsure:
