NMEA For VHF Radio DSC Connection
I would like connect my RDP149 to my Icom VHF for the DSC. I need about a 3 foot cable. I have looked up the cables in the manual but it shows some 6 pin and some 7 pin. I dont know which one I need. Could you please tell me which one I need or better yet a part number if you have it available. Also is there wiring diagram to connect to the radio. I have the radio end diagram. Is it just plug and play or is there some procedure to follow to get the Gps to recognize the radio.
Jack
Normally, Data port 2 (6 pin) connection would be used.
Typically the 6 pin data cable (000-154-054) is used to wire GPS data into the radio.
You would use the two output wires; WHITE (+) out and BLACK (-) out to the radio.
The white (+) out would go to the radio (+) input.
The black (-) out would go to the raido (-) input.
What would be the colors on that cable for the 2 input wires out from the radio into the gps?
