M Mickeyd43 New member Jun 3, 2025 #1 I have an MFD8 as slave to a MFD12 master. Is it OK to connect Data 1,2, and 3 to the slave. Will the master get the NMEA input from the MFD8?
TheReaper Moderator Staff member Jun 4, 2025 #2 Yes, that is fine. The installation wizard (IW) would have to be run on the master after the settings were done on the MFD8. Once in the IW on the MFD12, go to Global-Data Sources and select the appropriate sources coming from the MFD8.
