Does anyone know if the TZT2 is compatible with the new Yamaha Command Link Digital Display (6YC information station)? The display is able to read GPS data from a MFD, and mine is hooked up via NMEA 0183. Is there a certain setting the TZT2 needs to be in to allow it to output the correct information?
The VHF is also hooked up with NMEA 0183 and it is communicating with the TZT2, showing time and GPS coordinates.
Appreciate the input.
Thank you.
Thank you.
