When running higher speed it will have more gear noise; this is normal. If mounted on a posted it can reverb or amplify the sound and make it seem worse than it is. If your mounting hasn't changed but you find the noise too much, you can always change the radar to run a fixed speed of 24rpm. This will reduce the radar sampling due to the lower speed but the option is there.
