I have a 1670F, internal antenna.
Using the default map, i drive my boat and see my track as normal, as i get to the edge of the map you would expect the map to move in the same direction as you do - right. My other units do. Anyway what happens is i drive off the map. The map does not keep up with my vessel icon.
Any ideas as to what needs to be turned off or on or what i am failing to do?
I have been working at this for days and even called Furuno and spoke to someone there and no help.
