We have had a Navpilot 720 just installed on our Pacific Seacraft 37 cutter and we are running into a set-up issue. We have gone trough the installation setup to "Sea Trial" and the installation menu shows:
rudder limit setup Done
rudder test Done
Set Center Rud. Pos No
Compass Calibration Done
I'm guessing that the RRU sensor alignment step in the dockside setup is driving the set center rud pos line item. If we open the RRU sensor alignment step, the return to the screen is 1 degree to port which is inside of the allowable +/- 5 degrees. With the wheel centered, the notch on the RRU lines up nearly perfectly with the indicator .
any ideas on what I"m doing that is preventing the set center step from going to Done?
:sail
rudder test Done
:sail
