The problem I’m facing is my Furuno Navpilot 520 will complete dockside setup and rudder test successfully, but continually get “rudder drive error” when attempting to autocalibrate or use the autopilot in any conditions other than tolling speed in calm seas.
The AP system is a Navpilot 520 O/B using a Furuno HRP11-12 pump.
The boat is a 2120 Parker Pilothouse with Yamaha F225 outboard.
Steering is Seastar/Teleflex hydraulic helm (I believe the Seastar 2.0cu model HH5273)
and the steering cylinder is SeaStar/Teleflex HC53xx.
After the dockside setup, the rudder test usually reports deadband ~0.9deg, and PWM
duty cycle usually comes in at 55%, sometimes 60% and occasionally 50%. (according to installation manual, 50%-90% is within spec.) I don’t recall the rate of turn reported, but believe it was usually somewhere between 4.1-5deg/sec.
I had a chance to run the boat last weekend and found what might be an interesting
data point:
I met “rudder drive error” even when using the jog buttons to steer the boat but only in the starboard direction. At low speed (<5kts), I would not see any problems, but when the system was under load from the boat moving faster (~12kts in this case), the pump would fail to operate but only when trying to move rudder starboard.
If I pushed port jog, I could hear the pump operate and rudder would move port. If I pressed starboard jog, the arrow indicator on the LCD would indicate rudder command, but I could not hear the pump start.
If I continued to hold the starboard jog key down long enough, the system would report “rudder drive error”.
Does failure only under load and only in one direction sound consistent with any kind of pump failure you’ve seen before? Do you know if this suggests that I have a bad pump, or that the HRP11 is oversized/stalling and I need to drop down to the HRP05?
Thanks much in advance for your help!
data point:
