NAVPILOT-300 with Selanode
  • Thread starter Thread starter Holiday
H
Holiday
Is there not a possibility to connect the NAVpilot-300 to a hydraulic system with solenoid valves
Can you tell me why this is not possible and what is the difference with the connection of solenoids and a reversible hydraulic pump.
Solenoid drives systems are not supported by the NavPilot 300 by design. Solenoid drive requires three conductor SOL-A, SOL-B, and a common ground between them. The Navpilot 300 has two wire reversible output for driving a pump. While you might attempt to use it for what it isn't intended, it wouldn't be supported and bound to run into problems. The bottom line is it wasn't designed for Solenoid drive, Sailboats, Clutch drives and very large boats. The Navpilot 300 was designed for the small boat market centered around the center console market. The Navpilot 711c supports these other installs while offering both 0183 and 2000 support.
