I'm in the middle of installing the Navpilot 300... I have the processing unit installed along with the display head.
The installation is on a Grady White 306 Bimini 30' center console with twin 350hp Yamahas. I have a Seastar hydraulic steering system with power assist steering. I have done research into a AP pump. I am considering going with a Seastar AP1233 pump that mounts on the power assist unit. Will the Furuno Processing unit handle the Seastar AP1233 pump? Below is a picture of the power assist unit with the AP pump attached.
These are the specs for the Seastar AP1233 pump:
Type 2 Pump:
12 volts
1000 psi max system pressure
Flow Rate No Load: 100 cu in/min
Typical current draw: 5-11 amps
Cylinder Capacity: 12.5-21 cu in
The RAM capacities are 8.3 cu in each for a total of 16.6 cu in
Reply
Report Edit
Type 2 Pump:
12 volts
Reply
Report Edit
