Hi
Picked up this post from "the Reaper", below, that suggests adding an Actisense NGW-1 between Port 4 and a Seatalk NG network will provide nav data to the RDP149 at 4800bps, whilst at the same time picking AIS data from the Vesper XB8000 on Port 2 at 38400, could you please clarify if I have understood correctly? I have recently installed Seatalk NG so I can install an Actisene NGW-1 to interface to Port 4 if that works.
Re: AIS input on VX2 port 2 at 38.4kbs
Postby TheReaper » Wed Aug 13, 2014 11:18 am
If I understand you correctly, you now have both "nav data" and AIS coming in data2. If I am correct, then yes, once you added AIS, that violates the rule/"official stance". When AIS is input into data2, that's all that can be input on that port. If port 4 is available, you can have your nav data info come in there at 4800 baud with another NGW-1 using a 7-pin NMEA cable
