I have a DT800 connected to my MFD12 via furuno N2K cables: a 'backbone' cable from bilge to helm station; the DT800's lighter cable connected as a 'drop' cable via a 'T' at one end and the MFD connected via a lighter drop cable at the other end. Resistors both ends of the backbone. This network is powered via power applied to the designated DATA2 pins and a 1A fuse is in-line on the 12v+ side.
This network has to be coaxed into life. When I first power up the MFD, the DT800 depth/temp data is not visible but usually becomes visible after about 5 minutes. Longer than this, I pull the fuse and re-insert it and that will often bring the network to life. And yes, I've changed the fuse a few times, even though it has never been blown...makes no difference.
What should I check first??
thanks in advance
thanks in advance
