MSTZ hibernation
Status
Not open for further replies.
Hi, I have MSTZ Navigator installed on two Dell laptops I use on my C&C 40. I use a Globalstat USB gps antennae. I do not have it interfaced with other instruments yet. My problem is when I leave the computer unattended for some time the computer sleeps and when I wake it up it wont connect to the GPS. I even have trouble using the connection wizard and usually have to stop and restart MSTZ and then go through the wizard again. I contacted support and said there was an issue with this but was wondering if anyone has a solution?
Mark
Mark,
Unfortunately not much can be done with MaxSea to resolve the issue. It has more to do with Windows driver of the device not waking up after it is allowed to be shutdown/hibernate. I would be interested in the driver info showing up in windows for the device (GPS) you are using. Could you take a photo or screen shot of the Driver TAB of the Port properties for that device (under DEVICE MANAGER)? We would like to start tracking problem devices/drivers. To try resolving the issue, I would recommend you update the device driver to the most current available. If that doesn't work, then the only choice would be to setup the unit not to hibernate.
Johnny
Johny is right, one test you can do is to open up an hyperterminal on Windows and map it to the port of the NMEA0183 string coming from the GPS. After adjusting the speed and format you should see the sentences coming in.
Then leave the laptop for a while until it sleeps, and resume it. If hyperterminal shows the sentences entering again, then you have an issue with MaxSea. But if hyperterminal has lost its connection to the COM port then the issue is within your USB-Serial driver.
The problem with those USB-Serial is that the driver may not support suspend-resume. Maybe you are using the Prolific 2303 that usually come with the Globalsat, in that case i would invite you to test using hyperterminal (or any terminal capable of reading a COM port output in windows) and if it doesn't support suspend-resume then either check the firmware or change for another just to see. The problem can also be in windows...
Here is an excerpt from the documentation of the Prolific 2303:
http://www.prolific.com.tw/eng/Download-2.asp?ID=17
Finally, the PL-2303 USB to Serial adapter is a fully USB Specification compliant device and therefore supports advanced power management such as suspend and resume operations as well as remote wakeup. The PL-2303 USB Serial cable adapter is designed to work on all Windows operating systems.
Good luck,
Status
