In 2009 I removed my Mark-3 radar and GP-1850DF and went with a RDP148 (7” VX2) unit to run off of my existing RSB0071 radome. It became my chartplotter and radar. I also installed a PG500R heading sensor, NavPilot511 and FCV620 at that time. System worked flawlessly.
In 2012 I installed an RDP149 (10.4” VX2) in the dash and left the 7” overhead. Attached is my connection/network diagram. The system worked flawlessly most of the 2012 season. Towards the end of the season I intermittently received an alarm for missing heading data. The heading display on the radar screen would change to dashes. However, the navpilot LCD would continue to display proper heading at all times. My first thought was the cable from the pg500 AD10 to data 2 on the 7” so I bought another cable and proved it was not the cable. Both AD10 and NMEA from the PG500 would occasional result in the missing heading alarm. The 2012 season was cut short by Sandy.
The 2013 season started off with the same intermittent missing heading issue. After multiple sessions of on board diagnostics with Furuno phone tech support they recommended I pull the PG500 and send it into Camas, WA. I did and it proved to be functioning properly.
Per further review with Furuno phone tech support they feel that the data 2 port on the 7” is the problem and recommend that I send the 7” unit into Camas. I am not willing to give up my working radar until the offseason but will do then if needed. Right now I have a great working radar on the 7” for Heads Up only and no overlay.
As a work-around (and not shown on the attached diagram) I have re-routed heading to go from the PG500 AD10 port to data 3 on the 10.4” unit. This works fine for the 10.4” but when I turn on HDT to output over the network from the 10.4” to the 7” the heading locks up on both displays. I tried both AD10 and NMEA with same results.
Per review with Furuno phone tech support they say that you cannot send heading TO the Radar unit that heading must only come FROM the radar unit as part of the radar package. Seems odd though since the PG500 was originally connected to the 7” unit giving it heading. So what’s the difference between giving heading to the 7” direct from the PG500R versus over the network from the 10.4” unit which is now being fed by the PG500R? What am I missing here? Heading is heading, no? Is there anything else I can do or test shy of sending my 7" to Camas? I don't have another 7" unit to try, that would be nice..
Thanks.
Thanks.
